Rally pac ( help )
Rally pac ( help )
I need help please ? I have a 71 442. No clock. I’m going to put in rally pac. Other than the elbow/and sending unit. What else will I need ?
Wire to coil water temp sensor ?
and because I don’t have a clock what will I need to do ?
You’ve arrived at the right place for help with your Rally Pac installation.
This topic has been quite the discussion at this site in the past, so I’ve attached a few links for your perusal that should answer most of your questions and provide the tech aspect of the job.
The first link is to a sticky found in the Electrical section of this site and is titled: Rally Pack Wiring.
https://classicoldsmobile.com/forums/electrical-5/
And the following link is another link for you that can easily be found using the Google search tip that follows the link.
https://classicoldsmobile.com/forums...uestion-74712/
To search CO in better fashion, use Google with the following syntax example: “classicoldsmobile.com” xxx xxxx xxxx as your search option to find additional threads pertaining to this subject.
Still need additional help after all the reading? Then feel free to post your specific question and I’m certain someone will chime in with the answer.
Good luck with your installation….
If your adding the Tik Tom Tach, the wiring for the dash lamps and clock should be already there. Look for a gray wire behind the dash, that is the wire for the dash lights. There should also be a orange wire, that’s battery power for the clock. All you need to do is run a wire from the tach terminal of the tach to the negative side of the coil. If I remember correctly there is a 2 amp inline fuse on that wire.
Engr
