This AM/FM radio
was in the trunk of a car I bought. I would like to wire it up and test it. I just don't want to burn it up by incorrectly wiring it. I assume red and yellow wires are for power. Not sure of any of the others. Am I missing a 3 wire connection? Thanks
There should be a stamping on the top or bottom or both covers that shows the connections. The yellow is +12V, gray is the dial light (turns on and dims with the dash lights), brown is ground. The green & black wires are the front speakers, and the 3 pin connector is for the rear speakers (uses a common ground). I don't recall the pinouts, but again, check the covers for the stamping.
I have yet to see a Delco radio that doesn't have the stamping, it's subtle, but it should be there. BTW the red flying wire is a feed for the power antenna. I will try to find a picture of the pinouts and post it.
