Radio Wiring
Old Jun 1, 2021 | 03:49 PM
Phoenix8990's Avatar
Radio Wiring
This AM/FM radio
was in the trunk of a car I bought. I would like to wire it up and test it. I just don't want to burn it up by incorrectly wiring it. I assume red and yellow wires are for power. Not sure of any of the others. Am I missing a 3 wire connection? Thanks
Old Jun 1, 2021 | 04:27 PM
4R5's Avatar
4R5
There should be a stamping on the top or bottom or both covers that shows the connections. The yellow is +12V, gray is the dial light (turns on and dims with the dash lights), brown is ground. The green & black wires are the front speakers, and the 3 pin connector is for the rear speakers (uses a common ground). I don't recall the pinouts, but again, check the covers for the stamping.
Old Jun 1, 2021 | 05:10 PM
No information on the top or bottom of the radio, maybe inside? I think you got me going.
thanks
Old Jun 1, 2021 | 05:28 PM
4R5's Avatar
4R5
I have yet to see a Delco radio that doesn't have the stamping, it's subtle, but it should be there. BTW the red flying wire is a feed for the power antenna. I will try to find a picture of the pinouts and post it.
Old Jun 2, 2021 | 12:12 PM
ByronF's Avatar
check this thread it may have your answers
https://classicoldsmobile.com/forums...ronado-132285/
Old Jun 2, 2021 | 12:25 PM
4R5's Avatar
4R5
Here you go....
Old Jun 2, 2021 | 01:55 PM
oldoldss's Avatar
Here's a photo of a similar radio with the connections stamped in. They are the same as the reply above.
Old Jun 2, 2021 | 01:57 PM
Kensey's Avatar
You can also bench test it, less aggravating to do.
Get any 12V pug in charger and attached the wires accordingly. YouTube it, it's very easy.
Old Jun 2, 2021 | 10:47 PM
When bench testing, please use a fuse.
Old Jun 3, 2021 | 07:38 AM
I took a closer look and sure enough the info was there under the plug ins. What type speaker can I use 4 or 8 ohm?
Old Jun 3, 2021 | 04:57 PM
4R5's Avatar
4R5
Definately 8 ohm, 4 ohm speakers will make the output stages run very hot, possibly ruining the output transistors.
neatolds
Sep 9, 2015 09:46 PM
davoaz
Apr 20, 2015 12:48 AM
FinallyGotIt
Apr 28, 2014 06:07 PM
Wolf
Jun 6, 2011 05:44 AM
Chumley
Jan 15, 2007 05:27 PM
