power windows
Old Apr 13, 2011 | 01:36 PM
hippy72's Avatar
power windows
hi, I've got a '67 98 and the power windows are acting up. sometimes the windows won't work. Don't think it's the switches. Is there a relay somewhere that could be going bad? Thanks for any info, ken
Old Apr 13, 2011 | 02:58 PM
jensenracing77's Avatar
i don't think i can help with the problem but if you find you need something i may have it. that is if power window parts from a 66 will work on a 67.
Old Apr 13, 2011 | 03:35 PM
hippy72's Avatar
Thanks, but i found another guy with the same problem and I'm waiting to see if he'll say where he found the breaker. Thanks again
Old Apr 13, 2011 | 03:59 PM
Rickman48's Avatar
Check the wires that flex when you open the LF door - usually the biggest trouble spot - I've seen the plastic on the wires crack, and the wire itsef, too!
Pull back the rubber boot for inspection.
Old Apr 13, 2011 | 05:24 PM
hippy72's Avatar
Thanks, I'll check that too.
Old Apr 13, 2011 | 06:20 PM
I agree with Rickman48 about the wiring.
One more thing you might check: are the window units gummed up? With a car that old, the grease on the power window winder might be restricting or preventing movement in all but very hot weather. Just a thought....
Old Apr 14, 2011 | 04:08 PM
hippy72's Avatar
Thanks to both Rickman48 and Allen R. It was the wiring going in to the door.
Old Apr 14, 2011 | 04:22 PM
Rickman48's Avatar
Now - how do you plan on repairing it?
Used pieces are going to be as brittle, being 44 years old.
Old Apr 14, 2011 | 04:45 PM
hippy72's Avatar
pulled the door panel and spliced in new wires from the body side to inside the door.
socalrs
Aug 14, 2012 11:07 AM
squirell
Apr 13, 2011 05:22 PM
rustycarr
Mar 7, 2007 06:24 AM
jrbarrie83
Jul 4, 2006 09:16 AM
Geoffrey Hacker
Aug 1, 2004 01:05 PM
