Possible shorted antenna?
Old May 7, 2016 | 09:05 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
OK my AM radio did not work and now the Kenwood deck I picked up only had sound intermittently and is getting hotter than it should be. What resistance should the antenna have?
Old May 8, 2016 | 06:16 AM
I believe if you measure the resistance of the center pin on the antenna connecter to the outer shield you should read an open circuit. If you measure from the center pin to the antenna mast tip, you should read basically a short. Same with the outer side of the antenna connector to the mounting point on the antenna mast.
Old May 8, 2016 | 12:25 PM
Since your radio is a receiver only and not a transmitter, it would not get hot if the antenna is shorted.
Old May 9, 2016 | 09:18 PM
Frustrating, tape plays still no sound, nothing with the radio either, maybe it is this deck? I tried my other antenna and ran the ground wire right to the battery. Nothing, a radio would be nice.
Old May 10, 2016 | 05:40 AM
I'd check the speakers to start with.
Old May 10, 2016 | 08:00 PM
They are brand new but I am trying one out of my boat. I need to get my daughter's car fixed first.
Old May 11, 2016 | 10:09 PM
Different speaker, no dice. Never had so much trouble with stereos. Will a remote amp work, if the internal amp is shot? I may see if the CD player from my boat still works.
Old May 11, 2016 | 10:15 PM
By the way, the Tercel is unreal easy to work on. 15 minutes to change both head lights and 5 minutes for the inner door handle. Stupid domestic cars would require half the car stripped down. Reliable and has 350,000 km on it. My 88 had the outer door handle come unhooked, a lot bigger job.
curtis mayfield
Feb 21, 2023 07:13 AM
truckerlary
Jul 26, 2015 07:59 PM
dnmfranco
Sep 11, 2014 09:08 AM
elpresidente
Aug 2, 2014 07:19 AM
Redog
Feb 23, 2007 06:05 AM
