What style of Battery Cut-Off Switch
Looking for advice on a proper Battery Cut-Off switch for my 66 Track Pack Car.
I'm hoping to take it to a couple of 'test & tune's' this year, and I know I need one to be able to compete. I'm thinking I would want something that is unobtrusive, yet accessible. What are you using?
Summit n Jegs offer the high quality cut offs. Have a look. Then do the research to see whats allowed as far as where it needs to be mounted. Also check the rules...I dont think its required on a street car. Unless your into the 10s
My understanding is that if your battery is mounted in the trunk an external cutoff switch is required. I have done a lot of looking, there seems to be only a couple of general styles. Looking for suggestions based on what others in my situation have used.
Ideally, it could be set up so that it would be visible at the track and hidden for cruising (maybe wishful thinking).
I would run the rod type through an extra tail light housing. Pick up a spare drill the hole run the rod through. When your not at the track unscrew the rod and swap the housing, and your on the road again with no holes in the body.
Eric, that is a great idea! Thank You!
Kewl...
Pics of the completed mod please. And more pics of your track pack 1320 brawler. Id have 66 if I didn't have a 68 and no room. Missed my chance at a L69 many years ago...kick...kick...kick.
What is the tracks rule just out of curiosity...under a certain time you need a cage, fuel cell and a switch?
Eric your still getin the credit.
Steve
Steve
I'm getting foggy on this, but there's SOME Olds option that has a switch in the bumper behind the plate. I THINK it's factory air shocks, and maybe it's just the valve.
But, maybe you could mount a switch there, behind the plate, then take the plate off to race (and remember to put it back on when done).
The only thing that prevents me from considering this option is the fact that the gas tank is right there. A rear end collision and battery connections provide a spark and fuel enough to create a serious fire.
Agreed, plus I don't think there is enough room in that spot.
jmac69cutty's
Apr 13, 2009 07:42 AM
