Positive Battery Cable Problem, Need Help
Old Apr 27, 2012 | 11:42 AM
dephconn24's Avatar
Question Positive Battery Cable Problem, Need Help
just found out that my positive battery cable lead was resting against the manifold due to some shotty wiring from the guy before me.. now the wire is exposed in some parts with corrosion on the wire..
what would you guys recommend to get rid of corrosion and what tape should i re-wrap the cable in??
thanks in advance for the help
Old Apr 27, 2012 | 11:47 AM
74 Omega's Avatar
I would buy a new cable at the auto parts store, pretty cheap insurance to do it right.
Old Apr 27, 2012 | 11:57 AM
70cutlass831guy's Avatar
I had the same problem last week. I am working on a rebuild and my hot lead visibly looked ok but internally was rusted out causing poor connection to my starter which in turn was causing my starter to not crank. I replaced the hot lead with a 10 dollar napa auto parts cable and my starter fired right up.
Old Apr 27, 2012 | 11:59 AM
Rickman48's Avatar
X2 - chased a problem for 6 months, and it was a corroded positive cable, due to unhooked engine grounds!!
Cheap!!
Old Apr 27, 2012 | 01:15 PM
Or if you just want to cheap out heat shrink works well also!
Old Apr 27, 2012 | 05:04 PM
dephconn24's Avatar
thanks guys.. my car starts fine so it hasnt affected it yet but ill go out and purchase a new cable, indeed better safe than sorry
thanks again!
pogo69
Jun 6, 2015 04:40 PM
oldspackrat
Sep 18, 2014 03:48 AM
matviar
Apr 2, 2012 05:18 PM
joepenoso
Oct 16, 2011 11:46 AM
Del70
Sep 28, 2010 04:21 AM
