Pin Configurations
Old Feb 16, 2026 | 05:22 AM
richterolds's Avatar
Pin Configurations
Does anyone have (or can link me to) the pin change to be made on a '72 C/S when converting from idiot light guages to rallye pack? The '72 is different with the added fasten seat belt light.
TIA
All set, thank you. Found the answer.
Old Feb 16, 2026 | 04:48 PM
66SportCoupe's Avatar
Most 70 to 72 cars is a 2 wire swap for rallye pac. Depinning the 2 and swap and change the sending units.
Old Feb 17, 2026 | 04:15 PM
The info you need is in the stickies.
You also technically need to remove the green wire from the ignition switch for the temp gauge.
w1po
Feb 4, 2024 11:58 AM
Kiwicutlass
Jan 28, 2023 08:36 AM
scrappie
Feb 24, 2018 01:50 PM
costpenn
Jun 26, 2011 11:59 AM
Olds luvr
Jul 14, 2010 08:07 AM
