Parking light not working
Old June 13th, 2017, 05:25 AM
deadeyejedi's Avatar
Was doing a pre nys inspection check of my lights and noticed my drivers side parking light was out on my 1972 cutlass convertible .confirmed the bulb was good , and the signal light does work . There is only a blue and brown wire going to the fixture , the brown being the ground and the blue being power . If I hook my test lead to the blue wire coming out of the harness and to ground ,shouldn't it light up when I pull on the light switch? I get a very faint glow on the test light .where do I go from here . Btw all other lights are working fine. Thanks
deadeyejedi is online now
Old June 13th, 2017, 08:11 AM
You go to the opposite lamp after verifying a proper ground to the one that does not work. They are hooked in parallel.
oldcutlass is offline
Old June 13th, 2017, 08:23 AM
Thanks eric I'll do that when I get home
Old June 13th, 2017, 08:38 AM
Correction, the passenger light is powered off the drivers light. Check to see where the wires are spliced together, if you have side markers, the left side is spliced there also.
Old June 13th, 2017, 01:07 PM
Both grounds look good .im curious why the signal light works but not the parking light it appears they both get power from the same wire . Guess I need to start tracking it upstream .
Old June 13th, 2017, 04:53 PM
ok got this figured out had some bad connections and some miswiring by the previous owner ,found them inside the wiring harness .the blue wire coming from the firewall runs power to the signal lights and a brown wire in the same harness runs the parking lights and side marker lights all the connections are made inside the harness.i cleaned all wires and soldered them properly then shrink tube and electrical tape .and correction from above the brown wire is not the ground as i originally thought .the ground is through the housing itself bolted to the bumper .
Old June 13th, 2017, 06:21 PM
Glad you got it.
BeenThere
September 19th, 2015 07:11 AM
69'442
Brakes/Hydraulic Systems
March 30th, 2013 07:12 PM
Oldsmobilliam
December 1st, 2009 05:56 AM
nelsontj
September 19th, 2009 04:24 PM
cbogartjr
August 3rd, 2008 06:18 AM
Quick Reply: Parking light not working
