Parking brake light
Old Oct 1, 2024 | 04:31 PM
79cut's Avatar
Parking brake light
I have a 79 cutlass that has been modified wiring wise. P.O. put in a painless wiring kit along with a custom dash
my question is did these cars come with a emergency brake light switch ? That would turn on a light on the dash ?
I don’t see a switch on the pedal
Old Oct 3, 2024 | 11:51 AM
79cut's Avatar
They did. Combination warning lamp to 1) indicate pressure loss in either half of the brake hydraulic circuit and 2) to show the parking brake is engaged. The factory harness has a pin switch on the parking brake bracket.
But, since the car has an aftermarket Painintheass harness, all bets are off.
I'd look underhood to make sure the brake differential pressure switch is still wired in.
thanks. I will check
Old Nov 2, 2024 | 04:42 AM
79cut's Avatar
does anyone have a picture of how the emergency brake switch is connected to the pedal etc
Old Nov 3, 2024 | 09:27 AM
cjsdad's Avatar
Here is a picture of the parking brake assembly, showing the switch. This side is against the kick panel when installed. Essentially, the dark side of the moon! The switch contact can be reached with some difficulty (headstand in the floorboard, etc.) to connect the wire to it. When the brake is engaged, the switch closes. This grounds the circuit, turning on the interior brake light. Releasing the brake obviously opens the switch, turning the light off.
Old Nov 3, 2024 | 09:43 AM
79cut's Avatar
Thank you. This helps
Old Apr 5, 2025 | 07:04 AM
79cut's Avatar
im going to be tackling this soon. I’m sure my parking brake hasn’t been messed with
anyone know what colour wire went to this ?
this is extremely hard to see back there lol
GKranig1
Feb 16, 2023 05:51 PM
AcousticHash
Dec 7, 2022 09:42 PM
Bfg
Nov 15, 2020 01:32 PM
scooter123
Feb 17, 2012 10:58 AM
jo75olds
May 7, 2011 08:20 AM
