Oil gauge issue
Old Jun 22, 2025 | 10:01 AM
Cam989's Avatar
Oil gauge issue
I searched the subject and found some info but not exactly what I’m looking for. 1970 442 and somebody at some time swapped rally pack gauges in it. The wiring was as changed as per the diagrams I found. The issue I’m having is no key on the oil gauge reads a little below 1/2 or so. As soon as I turn key to on it pegs high. Running it makes no difference still max high. Turn key to off and it rests back around under half. The water temp and fuel gauge work fine as does the gen light. Bad sending unit? Wire grounding somewhere between gauge and sending unit?
Old Jun 22, 2025 | 10:06 AM
Cam989's Avatar
I also tried unhooking the wire from sending unit and also grounding the wire. All acts the same
deaddds
May 10, 2025 11:57 AM
Bills67
Oct 16, 2022 03:27 PM
dsouthard
Jun 6, 2017 06:31 PM
lemoldsnut
Nov 25, 2013 12:08 AM
my442conv
Nov 9, 2013 10:10 AM
