oil/choke light stays on 90 custom cruiser
Old Sep 27, 2009 | 03:14 PM
night_tigeronthehunt's Avatar
my oil/choke light stays on and i get an annoying dinging in my cruiser i have changed the oil and far as i can tell the choke is working right wasnt on when i first drove the car only came on after they replace the power steering pump. could this be a pinched wire or something simple like that??
Old Sep 27, 2009 | 03:53 PM
I'm pretty sure your CC does not use an electric choke, so the Oil/Choke light is really only an Oil light. With the key in the RUN position (but the engine not running) remove the wire from the oil sender under the hood. With the wire disconnected the light should go out. Now ground the wire. The light should go on. If these tests work, then the problem is either the sender or you really do have low oil pressure. If the tests do not work, you have a shorted wire.
Old Sep 27, 2009 | 04:46 PM
ok ty vm
N2ROW
Apr 11, 2015 10:04 AM
63super88
Mar 7, 2013 04:50 AM
442Dave
May 1, 2012 04:29 AM
dschallock
May 24, 2011 05:19 AM
jugdish
Jun 24, 2010 06:41 PM
