Oh No! I have a Short
well my progress on my 1967 Delmont 88 425 2bbl has come to a halt Got her up and running again and took her out for a spin one night and when I got home, I noticed a burning plastic smell so I opened my hood and to my surprise I saw my negative battery cable smoking which was odd and then the car would not even turn on . So today I went and bought a new battery cable, a new battery, I scored down all the connections that the car could have under the hood with a wire brush and greased them all up with the recommended grease... connected the negative cable (which was fine) and then connected my positive cable which sparked tremendously and zapped me pretty good which im assuming means that I have a short somewhere .... any ideas on how to fix it? or has anyone run into this problem before? Any help or opinions would be greatly appreciated.. oh, and on a side note (might be helpful, might not)... the initial ignition of the engine seems to take a while and about 3-4 times of turning the key on and off to get the car turned over and that's after I pump the pedal about 12 times to get fuel into the carb
Basically, disconnect everything, connect the battery, and start reconnecting things one at a time, until you see that spark again (do it with the doors closed to keep the dome light off).
Just follow the wiring schematic to see what leads to what.
The first place to start is by taking all of the red wires off of the horn relay (isolate the one from the starter so it doesn't touch anything else). If it still does it with those off, then the problem is in the wire to the starter solenoid, the starter solenoid, the starter, or the wire from the starter to the horn relay.
Work from there.
HonestDave
December 24th, 2013 06:56 PM
mm89olds
April 6th, 2006 11:03 AM
