OEM coil question
Old Oct 26, 2025 | 06:55 PM
Horsman's Avatar
OEM coil question
I need to replace my OEM AC Delco coil on my 71 Cutlass. Every replacement coil I find states must be used with external resistor. Also most state they are an oil filled canister.
Does the OEM Oldsmobile wiring have an external resistor built in?
Can you run an oil filled coil in the stock horizontal OEM position?
Can anyone recommend a stock appearing coil that can be used with the OEM points system?
Thanks in advance.
Old Oct 26, 2025 | 08:05 PM
GM products don't use a ballast resistor, they use resistor wire in it's place. Oil filled coils should be stood up (vertical), so you would want a 1.5 ohm, epoxy filled, 12v coil if you want to mount it horizontallly.
You can use a Pertronix 40111.
Old Oct 27, 2025 | 04:29 PM
Horsman's Avatar
Thank you Eric for the great information.
OLDsBARRY
Jul 4, 2025 01:03 PM
rket56
Sep 21, 2021 09:32 PM
olds 307 and 403
Jan 7, 2017 08:37 PM
ctrain22
Sep 6, 2009 08:37 AM
68conv455
Feb 20, 2008 02:36 AM
