no spark hei distributor
Old May 1st, 2023, 12:28 PM
Eckat0100's Avatar
hi, I ve no spark problem with my gm hei distributor. all parts on the ignition are new includes, wire, module, rotor, cap and distributor. no spark. tried the spark plug wires with the spark plugs on my second car (opel kadett) and there I have spark. car is a 84 trans am.
Eckat0100 is offline
Old May 1st, 2023, 01:23 PM
First thing’s first: did it run before you changed all the parts? Does the rotor turn while Chris king the engine? Do you have power at the batt terminal on the cap?
If you have power at the cap, move your test light to the tach terminal. Turn on the ignition, the light should come on. If not, the ignition coil primary winding is open, replace the ignition coil.
Next, crank the engine with the test light still on the tach terminal. The test light should flicker. If not, either ignition module is defective, or the pickup coil is bad. Inspect the tiny wires that go from the pickup coil to the ignition module. Sometimes the wires break from the vacuum advance moving.
matt69olds is offline
Old May 1st, 2023, 01:48 PM
Eckat0100's Avatar
every wires in good shape. car does run sometimes for 2 minutes no longer. but now it doesnt run for a while. just cranking. rotor turns while cranking. parts all new.
Old May 1st, 2023, 04:49 PM
oldolds88's Avatar
change the inner coil,its under the plate
oldolds88 is offline
Old May 1st, 2023, 04:56 PM
Originally Posted by Eckat0100
parts all new.
New parts do not always work properly.
Do the tests that matt suggested above to isolate the problem.
Fun71 is offline
Old May 2nd, 2023, 12:55 AM
Eckat0100's Avatar
repair
test light good enough or Multimeter better? what ohm reading on the pink batt and yellow tach cable should I habe? key off, on, and crank position? Cheers
Old May 4th, 2023, 08:48 PM
Eckat0100's Avatar
repair
with a 2,5 mm battery cable mounted on the pink coil batt cable terminal and battery plus itself the engine runs.
Old May 10th, 2023, 02:07 AM
Eckat0100's Avatar
no spark
think I loose voltage by cranking the engine. is the ignition switch a different part as the lockable key on a 84 trans am?
Old May 16th, 2023, 03:24 AM
Eckat0100's Avatar
no spark
can I get power from the fuse box IGN to the coil? does the coil resist this methode?
Old May 16th, 2023, 04:50 AM
Yes you can us the IGN terminal. Why not just run a temporary jumper from the battery to the HEI (you still start it with the key)? Disconnect the tach, if one is connected and see if you can get the engine to run. Just note, if the engine starts, in order to turn it off the temporary jumper needs to be disconnected.
oldcutlass is online now
Old May 18th, 2023, 03:47 PM
Eckat0100's Avatar
no spark
yes I tested before with jumper cable from battery to coil and engine runs. as you said I had to remove this cable to shut off the engine then. on the unfused IGN place on the fuse box I tested with multimeter for Voltage on different key position. it has no power at off position but 12 volt power at the on and start (crank). So I think this is perfect
and I can start and shut off the engine with the key again. Do you know what male to female terminal connector I need to install the new 12 gauge cable on the IGN fuse box place?
Old May 18th, 2023, 03:53 PM
Eckat0100's Avatar
no spark
it looks like the half of a fuse tooth as installed on the fused places down on the fuse box just a little thinner tooth. dont know the Name and where I can get it here in austria
Old May 18th, 2023, 04:01 PM
The IGN terminal is a 1/4" spade, it is also fused by the adjacent Dir Sig - Backup fuse.
Old May 18th, 2023, 05:26 PM
Eckat0100's Avatar
no spark
dont understand your last message very well. I need the name of the connector that I have to put in to this spade and also the size. regards
Old May 18th, 2023, 07:18 PM
It's called a female spade terminal, you can use any variation of it. I'd run a 14 or 12ga wire.
Old May 19th, 2023, 02:07 AM
Eckat0100's Avatar
no spark
what size? think I need this one
Old May 19th, 2023, 04:03 AM
The one you posted is a male terminal, you need a female. Also the colors designate the use with particular wire gauge sizes, blue will work.
Old May 19th, 2023, 04:20 AM
Eckat0100's Avatar
no spark
have bought this male terminal and installed. have 12 volt power now from the IGN fuse box terminal place up to the distributor coil. nothing changed. cant fire the engine up. no spark. I dont understand why I can fire the engine up with a cable voltage directly from the battery to the coil but not from the IGN fuse place to the coil. what is the difference. also the fuse box place BATT where always 12 volts sits on dont work.
Old May 19th, 2023, 04:37 AM
Do you have voltage at the IGN terminal, if not check the fuse marked Dir Sig/Backup.
Old May 19th, 2023, 04:57 AM
Eckat0100's Avatar
no spark
yes I have power.
Old May 19th, 2023, 04:59 AM
Eckat0100's Avatar
no spark
dont understand this hole piece of....
Old May 19th, 2023, 05:23 AM
If you have power and it worked directly off the battery, it should work connected to the fuse block. Do the directional signals work?
Old May 19th, 2023, 05:48 AM
Eckat0100's Avatar
no spark
I think so too. I check thema when I come home today. I think its all about voltage loss or voltage Transfer problem during turning the key to crank position
Old May 19th, 2023, 06:29 AM
If you are still running the stock starter, connect the yellow wire that runs from the solenoid R terminal to the power wire to the HEI. That should eliminate the low voltage start problem.
Old May 19th, 2023, 06:42 AM
Eckat0100's Avatar
no spark
there is no wire connected to the r terminal on the starter. Main battery cable on top (and a other 2 smaller wires with a separate connector are at the top places there too), and on the s terminal on the right side there is a pink/purple thicker cable installed. cant say the color of this exactly
Old May 19th, 2023, 06:54 AM
Connect a wire from the R terminal to the HEI power wire at the distributor.
Old May 19th, 2023, 06:59 AM
Eckat0100's Avatar
no spark
should I connect it to the wire of the hei Power wire on the coil or delete the wire from the coil and run a New wire from the starter s to the coil batt connection?
Old May 19th, 2023, 07:04 AM
Connect them both together.
Old May 19th, 2023, 07:48 AM
Eckat0100's Avatar
no spark
So just strip the insulation of both wires and Twist the core together Russian style and isolate it with tape?
Old May 19th, 2023, 09:49 AM
I like solder and heat shrink or a mechanical connection like a butt connector.
Old May 19th, 2023, 02:48 PM
  #31
Eckat0100's Avatar
no spark
yes but I am not a mechanic. I do it the russian way. if it works it can be repaired professionally later. if this works can I stop the engine with key again?
Old May 19th, 2023, 03:54 PM
  #32
Yes, the key will work.
Old May 20th, 2023, 02:39 AM
  #33
Eckat0100's Avatar
no spark
I have no power on the starter r and s terminal in key off and on position. I dont know if I have power at crank position? dont know how it should be
Old May 20th, 2023, 04:59 AM
  #34
IF you have no power at the R terminal with the key on (feeding back through the HEI wire) then you're not getting power through the IGN terminal.
Old May 20th, 2023, 05:28 AM
  #35
Eckat0100's Avatar
no spark
declaration: I have not installed the cable on the r terminal. tested the connection only. I get lower than 12 volts (cant say exactly) on the r and s terminals just only by cranking the engine
Old May 20th, 2023, 05:32 AM
  #36
The R terminal is an out put from the starter solenoid and will only have voltage is the starter is energized. The S terminal will only have voltage as an input to energize the starter solenoid when the key is in the crank position.
Old May 20th, 2023, 08:56 AM
  #37
Eckat0100's Avatar
starter energized! voltage on both the r and s terminal only if the engine cranks or key in start (crank) position if you want. checked it out today with test light
Old May 20th, 2023, 09:28 AM
  #38
Eckat0100's Avatar
directional signals work!
Old May 20th, 2023, 09:41 AM
  #39
Eric - Nice work assisting the OP.
Vintage Chief is online now
Old May 20th, 2023, 09:55 AM
  #40
Does the engine run?
Quick Reply: no spark hei distributor
