No spark on 72 Cutlass
Old Oct 26, 2025 | 09:42 PM
72Cutlass4door's Avatar
I am the new owner of a 72 Cutlass 4door, I have no spark, the car came with multiple plug wire sets and distributor caps, papers of the firing order, it’s got two coils loose on top the engine, he’s got a new coil with the old coil and bracket/condenser still attached. This all tells me he was having ignition issues and gave up. I have 5volts at the coil with key on, no spark at plugs, timing seems to be correct, could it be as simple as new points?
Old Oct 27, 2025 | 04:02 AM
Read through this:
Troubleshooting a points ignition - ClassicOldsmobile.com
Old Oct 27, 2025 | 07:30 AM
OLdGreenPaint's Avatar
That is some good stuff! A fun read of the entire Sticky. Wonder if any of the posters are still hangin around? On my 72 cutlass, I think I changed plugs, points, wires, condenser. Still had an intermittent once in a while ignition miss. Replaced the distributor cap and now the ignition is rock solid. Amazing how much of what I knew in 1970 I had forgotten.
Old Oct 27, 2025 | 08:20 AM
7thof11's Avatar
When I got my 72 cutlass the battery had the screws and not the post. No solid connection. Bought a new battery with the posts. Problem solved
Custlasss1972
Jun 15, 2023 05:46 PM
deadeyejedi
Jul 21, 2021 07:06 PM
rktolds
Dec 18, 2017 04:44 PM
Matt Hohmann
Aug 5, 2013 12:39 PM
jonesolds442
Jul 24, 2013 02:43 PM
