72 350 no start
Old Dec 18, 2017 | 12:23 PM
rktolds's Avatar
72 350 no start
Electric issue on 72 350 Supreme convertible .No spark to plugs. Spark at coil when I open the points with screwdriver. No spark at coil wire when I crank.
Ive followed the steps outlined in the sticky. New plug wires and plugs. What am I missing?
Matt
Old Dec 18, 2017 | 01:31 PM
If you have power at the coil+ terminal I'd say your points not opening or a bad condenser.
Old Dec 18, 2017 | 03:23 PM
X2. Misadjusted points is the most likely cause. Also look at a possible defective rotor - I've had a brand new rotor that was shorted under the center contact and grounded to the distributor shaft. You can just imagine the cursing when I finally found THAT problem!
Finally, be sure the distributor is turning when you crank the motor. If the timing chain came off due to a worn cam gear, you won't get spark.
Old Dec 18, 2017 | 03:48 PM
rktolds's Avatar
I swapped in a newly rebuilt distributor that I havent delivered to a buddy. It has fire now. Popping and sputtering so probably one tooth off. Thanks for
the help guys.
Matt
Old Dec 18, 2017 | 03:58 PM
Or 180 out.
Old Dec 18, 2017 | 04:44 PM
Um, another thing is to ensure that there is actually a rotor under the cap. Not saying that I have ever forgotten to put one back prior to attaching the cap and wires, but I've heard of it happening to some folks.
colemane
Apr 13, 2013 01:19 PM
Destructor
Oct 22, 2010 05:35 PM
rrielley
Sep 1, 2008 03:00 AM
1973_442
Mar 22, 2007 05:42 PM
emarkay
Dec 8, 2004 08:23 AM
