No Power at starter/neutral safety switch
Need help guys. 66 cutlass 330 engine. Here's what I got. Headlights work, no taillights/brake lights/reverse lights. When I turn the key dash lights come on. When I move to start... nothing. No Click...nothin. The battery is new. power at the relay. Testing large nut side at starter no power. Key on. No power at solenoid when key moved to start. Moved to a neutral safety switch. Removed the two purple wires from the safety switch. Tested both wires. No power. No difference in voltage moving to start position.
For clarity. The starter should always have power correct? In addition, the two purple safety switch wires, constant power? Terminals and wires are all clean. Any guidance would be appreciated.
Thank you for that Clarity. I have no power at starter and no power in any capacity to the safety switch. There is power at the relay and coil. Any guidance for the next steps would be very much appreciated.
If you have power at the horn relay stud then the terminals are corroded or making a bad connection for some reason. That stud is where power is distributed to the rest of the car. Note a volt meter will read voltage with the littlest connection but the connection will fail under load.
Get a test light. Start at the battery and trace the circuit until you find where the power stops. There's no magic here, just thorough troubleshooting.
Also keep in mind that the circuit needs the ground cable to be clean and tight in addition to the power cable.
@joe_padavano Thank you, Joe. I've been using my Voltmeter. I tested all the fuses. Here's what I got. Power at the terminal. That goes to the relay. The nut and bolt on the relay read 0. But the cables read 12. So Terminal to relay good. No power at stud. Cable from relay good cable touching starter no power. I have no power at the neutral safety switch, under the center console. No power underhood for neutral safety switch junction going to the starter.
