No output from coil
Old September 9th, 2015, 03:21 PM
yalikeme's Avatar
No output from coil
I have installed a new MSD coil and distributor in my 68 olds cutlass. I have 12V coming in to the coil, but nothing coming out, thus no fire to the distributor. I have attached two wires to the posts on the coil, and inserted the coil wire to the distributor, but still no fire. Any suggestions!!!
Bob Wormell
yalikeme@Hotmail.com
yalikeme is offline
Old September 9th, 2015, 08:19 PM
Is it points?
oldcutlass is offline
Old September 9th, 2015, 08:33 PM
yalikeme's Avatar
Is it points?
yalikeme is offline
Old September 9th, 2015, 08:36 PM
yalikeme's Avatar
No points
I think the distributor is electronic, doesn't have points. The schematic calls for an amplifier, and I can't find it, any help we be appreciated.
yalikeme is offline
Old September 10th, 2015, 06:11 AM
We're all happy to help, but the mind reading thing still isn't working. You need to tell us exactly what distributor setup you have, what else has been done to the wiring, and what the symptoms are. A statement like "I think the distributor is electronic..." doesn't help with a diagnosis. If nothing else, pull off the cap and take some photos.
joe_padavano is offline
Old September 10th, 2015, 08:46 AM
yalikeme's Avatar
Thank you, I will get the exact number of the coil and distributor, to better help you with my problem.
yalikeme is offline
Old September 10th, 2015, 10:27 AM
steverw's Avatar
Did you put the rotor on it?
steverw is offline
Aceshigh
December 9th, 2013 09:56 AM
yeahbuddy
March 6th, 2012 04:22 AM
Vega
January 23rd, 2012 11:56 AM
geckonz08
March 17th, 2010 04:50 PM
drewt
March 16th, 2010 07:18 PM
Quick Reply: No output from coil
