Newbe helping a friend with his 77 Cutlass. Can anyone help with a couple questions?
Old Jul 24, 2016 | 10:00 AM
scootinz's Avatar
Hey everyone just found these forms and thought I'd post a couple questions. Helping a friend get the mothballs out of a 77 Cutlass that's been sitting awhile. When I lifted the hood I noticed a connector coming out of the firewall that goes to another connector with a small moumting bracket for it. Seems like it goes somewhere on the passenger side. Anyone have any clue what this goes to? Don't see anything on the alternator or air cleaner housing.
Anyone got a clue where this goes on a 77 Cutlass?
The next thing I noticed is I know there's a breather on the driver side valve cover not the air filter housing also has a hole for the other style breather you see on other GM's. Is this car supposed to have one over there as well? Looks like somebody's been in here and made a hodgepodge out of some of the hoses for the air filter housing.
This is just dangling under the air cleaner not sure if it's routed properly and the vacuum advance vacuum line is just pluged with a screw coming from the distributor
Also the rubber elbow coming out of the air cleaner to the breeder is shot. Local Napa doesn't carry it. I'm sure it's not rocket science to find but if anyone has a quick link for these or to keep the original look let me know.
Lastly, what should I be setting the timing at with today's fuel on this car?
Thanks for your advice in advance guys....car seems to run pretty good but they just want to freshen up a little. It's been sitting about 6 years and all the rubber is from the eighties so I'm going to dump fluids belts hoses tune-up etc. Original owner 82k
Old Jul 24, 2016 | 10:11 AM
2blu442's Avatar
The first picture is the hood light connector. The light should be attached to the underside of the hood in that general area.
John
Old Jul 24, 2016 | 12:44 PM
scootinz's Avatar
John
Duh.... that was an easy one. Didn't catch that one because the light is long gone apparently. Thanks John
Old Jul 24, 2016 | 05:43 PM
The underhood light was an option and likely was never there. The pigtail and connector was built into every harness.
The rubber elbow on the air cleaner is Dorman P/N 47039. NAPA sells the same part under P/N NOE 7351680.
The vacuum switch is the Choke Thermal Vacuum Switch (CTVS) and actually is supposed to be clipped into the side of the air cleaner housing.
This one isn't exactly the same, but you get the idea
Old Jul 25, 2016 | 06:22 AM
scootinz's Avatar
Huge help Joe....thank you! Makes sense now. The opening in the air cleaner housing that I thought was for the old style breather is where that goes. And I'm surprised they put the pigtail in for the hood light when they could have easily saved a few pennies by not connecting it by the firewall. Thanks for supplying the NAPA part number on the elbow. They weren't sure what it was and I was going to bring it up there today to match it up. Really appreciate your help thanks again!
Old Jul 25, 2016 | 06:53 AM
It depends on whether your going back to stock or not as to where to hook up the vacuum for the dist.
Old Jul 25, 2016 | 07:02 AM
scootinz's Avatar
Well, it occurred to me that Joes chart showed everything so I don't even know why I was asking lol car looks pretty stock and I know a lot of old school guys would disconnect vacuum advance and I've done a lot of reading on it and it seems to raise idle temperatures and kills fuel economy. This car is no race car and it's going to be driven mainly by a woman and an older guy so I'm just pretty much putting it back to stock. Great write up on vacuum advance below.
TIMING AND VACUUM ADVANCE 101 The most important concept to understand is that lean mixtures, such as at idle and steady highway cruise, take longer to burn than rich mixtures; idle in particular, as idle mixture is affected by exhaust gas dilution. This requires that lean mixtures have "the fire lit" earlier in the compression cycle (spark timing advanced), allowing more burn time so that peak cylinder pressure is reached just after TDC for peak efficiency and reduced exhaust gas temperature (wasted combustion energy). Rich mixtures, on the other hand, burn faster than lean mixtures, so they need to have "the fire lit" later in the compression cycle (spark timing retarded slightly) so maximum cylinder pressure is still achieved at the same point after TDC as with the lean mixture, for maximum efficiency. The centrifugal advance system in a distributor advances spark timing purely as a function of engine rpm (irrespective of engine load or operating conditions), with the amount of advance and the rate at which it comes in determined by the weights and springs on top of the autocam mechanism. The amount of advance added by the distributor, combined with initial static timing, is "total timing" (i.e., the 34-36 degrees at high rpm that most SBC's like). Vacuum advance has absolutely nothing to do with total timing or performance, as when the throttle is opened, manifold vacuum drops essentially to zero, and the vacuum advance drops out entirely; it has no part in the "total timing" equation. At idle, the engine needs additional spark advance in order to fire that lean, diluted mixture earlier in order to develop maximum cylinder pressure at the proper point, so the vacuum advance can (connected to manifold vacuum, not "ported" vacuum - more on that aberration later) is activated by the high manifold vacuum, and adds about 15 degrees of spark advance, on top of the initial static timing setting (i.e., if your static timing is at 10 degrees, at idle it's actually around 25 degrees with the vacuum advance connected). The same thing occurs at steady-state highway cruise; the mixture is lean, takes longer to burn, the load on the engine is low, the manifold vacuum is high, so the vacuum advance is again deployed, and if you had a timing light set up so you could see the balancer as you were going down the highway, you'd see about 50 degrees advance (10 degrees initial, 20-25 degrees from the centrifugal advance, and 15 degrees from the vacuum advance) at steady-state cruise (it only takes about 40 horsepower to cruise at 50mph). When you accelerate, the mixture is instantly enriched (by the accelerator pump, power valve, etc.), burns faster, doesn't need the additional spark advance, and when the throttle plates open, manifold vacuum drops, and the vacuum advance can returns to zero, retarding the spark timing back to what is provided by the initial static timing plus the centrifugal advance provided by the distributor at that engine rpm; the vacuum advance doesn't come back into play until you back off the gas and manifold vacuum increases again as you return to steady-state cruise, when the mixture again becomes lean. The key difference is that centrifugal advance (in the distributor autocam via weights and springs) is purely rpm-sensitive; nothing changes it except changes in rpm. Vacuum advance, on the other hand, responds to engine load and rapidly-changing operating conditions, providing the correct degree of spark advance at any point in time based on engine load, to deal with both lean and rich mixture conditions. By today's terms, this was a relatively crude mechanical system, but it did a good job of optimizing engine efficiency, throttle response, fuel economy, and idle cooling, with absolutely ZERO effect on wide-open throttle performance, as vacuum advance is inoperative under wide-open throttle conditions. In modern cars with computerized engine controllers, all those sensors and the controller change both mixture and spark timing 50 to 100 times per second, and we don't even HAVE a distributor any more - it's all electronic. Now, to the widely-misunderstood manifold-vs.-ported vacuum aberration. After 30-40 years of controlling vacuum advance with full manifold vacuum, along came emissions requirements, years before catalytic converter technology had been developed, and all manner of crude band-aid systems were developed to try and reduce hydrocarbons and oxides of nitrogen in the exhaust stream. One of these band-aids was "ported spark", which moved the vacuum pickup orifice in the carburetor venturi from below the throttle plate (where it was exposed to full manifold vacuum at idle) to above the throttle plate, where it saw no manifold vacuum at all at idle. This meant the vacuum advance was inoperative at idle (retarding spark timing from its optimum value), and these applications also had VERY low initial static timing (usually 4 degrees or less, and some actually were set at 2 degrees AFTER TDC). This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it. If you look at the centrifugal advance calibrations for these "ported spark, late-timed" engines, you'll see that instead of having 20 degrees of advance, they had up to 34 degrees of advance in the distributor, in order to get back to the 34-36 degrees "total timing" at high rpm wide-open throttle to get some of the performance back. The vacuum advance still worked at steady-state highway cruise (lean mixture = low emissions), but it was inoperative at idle, which caused all manner of problems - "ported vacuum" was strictly an early, pre-converter crude emissions strategy, and nothing more. What about the Harry high-school non-vacuum advance polished billet "whizbang" distributors you see in the Summit and Jeg's catalogs? They're JUNK on a street-driven car, but some people keep buying them because they're "race car" parts, so they must be "good for my car" - they're NOT. "Race cars" run at wide-open throttle, rich mixture, full load, and high rpm all the time, so they don't need a system (vacuum advance) to deal with the full range of driving conditions encountered in street operation. Anyone driving a street-driven car without manifold-connected vacuum advance is sacrificing idle cooling, throttle response, engine efficiency, and fuel economy, probably because they don't understand what vacuum advance is, how it works, and what it's for - there are lots of long-time experienced "mechanics" who don't understand the principles and operation of vacuum advance either, so they're not alone. Vacuum advance calibrations are different between stock engines and modified engines, especially if you have a lot of cam and have relatively low manifold vacuum at idle. Most stock vacuum advance cans aren’t fully-deployed until they see about 15” Hg. Manifold vacuum, so those cans don’t work very well on a modified engine; with less than 15” Hg. at a rough idle, the stock can will “dither” in and out in response to the rapidly-changing manifold vacuum, constantly varying the amount of vacuum advance, which creates an unstable idle. Modified engines with more cam that generate less than 15” Hg. of vacuum at idle need a vacuum advance can that’s fully-deployed at least 1”, preferably 2” of vacuum less than idle vacuum level so idle advance is solid and stable; the Echlin #VC-1810 advance can (about $10 at NAPA) provides the same amount of advance as the stock can (15 degrees), but is fully-deployed at only 8” of vacuum, so there is no variation in idle timing even with a stout cam. For peak engine performance, driveability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to full manifold vacuum. Absolutely. Positively. Don't ask Summit or Jeg's about it – they don’t understand it, they're on commission, and they want to sell "race car" parts.
Old Jul 25, 2016 | 07:54 AM
The manifold vs ported vacuum advance is an on going argument that has been around since the 70's. Its personal preference and whether your engine likes it or not. Street cars generally benefit from vacuum advance that's properly set up. The people that prefer not to is because they don't understand how/why it causes the engine to ping after modifying their distributors timing curve.
Old Jul 25, 2016 | 08:18 AM
Actually, the base harness has connectors in place for all the available options. It made life much easier on the assembly line.
canzoman
Apr 20, 2015 02:51 PM
ken45
Apr 3, 2013 12:41 PM
lshlsh2
Aug 22, 2012 10:35 AM
RAMBOW
Nov 8, 2011 12:46 PM
70 cutlass s
Jun 30, 2011 04:01 PM
