neutral safety switch wiring
Old Jan 14, 2013 | 12:15 AM
onofre442's Avatar
hello, i am doing my conversion from column shift to console shift on my 1968 442. i have finally got the neutral safety switch and the wiring. my question is, where can i plug the female connectors (purple wires) from the neutral safety switch from the shifter console?.. or can i just plug it to the existing neutral safety switch of the existing steering column? help!!!
Old Jan 14, 2013 | 04:28 AM
On my 69 the console wiring (neutral safety and back-up lights) connect to the same connectors that went to the switch on the column. In other words, unplug the switch on the column, plug in the console switches.
Old Jan 14, 2013 | 07:12 AM
Well, the switch on the column won't be connected to the linkage anymore, so plugging into that won't do a lot for you...
As noted, the factory console harness has a jumper in it that plugs into the NSS connectors under the dash and runs to the NSS on the shifter for the 1968 cars.
Old Jan 14, 2013 | 11:28 AM
onofre442's Avatar
Where is NSS connectors under the dash? Will I just follow the purple wire from column?
Old Jan 14, 2013 | 11:48 AM
The connector on the column is the one I'm talking about. Unplug from the column NSS and plug that same connector into the console harness. Same thing for the green backup light wires, by the way.
Old Jan 14, 2013 | 12:26 PM
onofre442's Avatar
ok got it!!! thank you...
Old Jan 14, 2013 | 12:28 PM
onofre442's Avatar
thank you matt69olds...
Old Feb 24, 2013 | 10:33 PM
onofre442's Avatar
hi joe, im following your leads and im about to do it sometimes this week. as you stated, wires (purple) from column nss need to be connected to the console harness. wirings have female connectors (spade type) on both end, is there a jumper that i can use to connect them? or should i cut from each end and use connectors? also, ive taken some pictures while im doing the conversion, (column to console),i would like to post them when im done. needs instructions on how to load pictures....thank you
oldspackrat
Nov 17, 2014 06:31 AM
70 ctls
Jan 28, 2009 03:20 PM
OhMyOlds
Aurora
Oct 21, 2007 12:44 AM
footbrake
Jun 12, 2006 06:10 PM
oldsnut7098
Aug 10, 2003 10:06 PM
