negative battery post cable
Old Aug 26, 2017 | 06:27 PM
niko000's Avatar
can I connect it to the alternator housing?
Old Aug 26, 2017 | 06:54 PM
don71's Avatar
same but different
I wouldn't do that. Its poor practice.
Your negative battery cable should always go to the engine block/head. The rest of the car needs a good ground source too, not just the alternator.
Old Aug 27, 2017 | 06:05 AM
Why would you want to? The largest current draw by far is the starter motor. The negative cable needs to be bolted directly to the block to minimize resistance and thus prevent hard starting. Any additional bolted joints between the cable attachment and the starter will only increase resistance and eventually cause hard starting. The factory location is typically at the front of the block under the PS pump, usually on a stud that bolts directly to the block.
Old Aug 27, 2017 | 04:39 PM
Ozzie's Avatar
I agree with what has been said. If you feel that the alternator needs better grounding, run a separate wire to better ground its case.
68Tom
Sep 12, 2024 01:57 PM
rothlane'68
Aug 1, 2017 06:17 PM
rktolds
Nov 8, 2014 06:53 AM
Mr Shifty Sidney
Sep 28, 2013 05:20 PM
78ChevOlds
Aug 19, 2011 05:28 AM
