Need help what is this for?
Old Aug 4, 2017 | 04:31 PM
Rustbucket2's Avatar
working on my 70 cutlass, and some under dash wires are cut, this is one of those wires. one end is cut off, the other has this crazy looking connector, where will it plug in at?
Old Aug 4, 2017 | 06:45 PM
That connector goes to the pin switch on the door jamb for your dome light. If it doesn't work, this is why.
Old Aug 5, 2017 | 03:45 AM
I don't know if light works. it is a shell right now. I bought the car in boxes, so tracking things down, and finding all the parts is taking a lot of time,The one thing I over looked, door jam switch, thanks Joe.
Old Aug 5, 2017 | 07:50 AM
Here is one more yellow with black stripe. what is it to hook in to? and why would someone cut it?
Old Aug 5, 2017 | 09:02 AM
Why would someone cut it? Because someone was a moron.
I suggest you get your hands on a 1970 Chassis Service Manual, which has the color coded wiring diagram in Chapter 12.
Is that the steering column connector?
Old Aug 5, 2017 | 09:43 AM
Triharder's Avatar
Hi. On my 72 the yellow and black wire traced back to the seat belt warning system. Mine was cut further down the line.
Old Aug 5, 2017 | 09:45 AM
The OP's 1970 doesn't have a seatbelt warning system, which is why one needs to look at the correct wiring diagram in the CSM.
Old Aug 5, 2017 | 09:47 AM
Triharder's Avatar
I have those connectors as well. Still trying to figure them out. I have wires to my pin switches but the wires are different colours, lights work fine. Hopefully someone will recognize them.
Old Aug 5, 2017 | 03:41 PM
Joe,
yes, that is the steering column connector.
Old Aug 5, 2017 | 03:48 PM
Joe, you were 100% on door jams, found this in box, with tail lights
Old Aug 5, 2017 | 05:22 PM
svnt442's Avatar
Old Aug 5, 2017 | 05:30 PM
svnt442 Thanks so much for wire diagram
Old Aug 5, 2017 | 06:48 PM
svnt442's Avatar
Not a problem and you are quite welcome.
meoff
Site Help
Aug 29, 2013 12:15 PM
coppercutlass
Mar 1, 2013 07:33 AM
cutlassclay
May 11, 2012 06:31 AM
MJAKS462
Apr 15, 2010 02:34 PM
silverriff
Mar 24, 2010 06:36 PM
