Need help what is this for?
working on my 70 cutlass, and some under dash wires are cut, this is one of those wires. one end is cut off, the other has this crazy looking connector, where will it plug in at?
That connector goes to the pin switch on the door jamb for your dome light. If it doesn't work, this is why.
I don't know if light works. it is a shell right now. I bought the car in boxes, so tracking things down, and finding all the parts is taking a lot of time,The one thing I over looked, door jam switch, thanks Joe.
I suggest you get your hands on a 1970 Chassis Service Manual, which has the color coded wiring diagram in Chapter 12.
Is that the steering column connector?
