Need help identifying another plug
Old May 8, 2023 | 05:36 AM
prlynch01's Avatar
Can someone identify the plug in the attached photos? 70 442, original carburetor, distributor and coil with external resistor, automatic, AC. The wires are green and the plug was tucked behind the back of the motor behind the distributor when I bought the car. Obviously the connector has seen better days. Any help would be appreciated. Thx.
Old May 8, 2023 | 06:13 AM
Is it time for the monthly TCS question?
Yes, this connector goes to the solenoid valve for the transmission controlled spark system, a prehistoric emissions control system designed to reduce NOx emissions by disabling vacuum advance in the lower gears. Apparently yours has been bypassed. Nice mouse-nibbling on the connector body.
Old May 9, 2023 | 06:26 PM
prlynch01's Avatar
Thanks Joe. I confirmed today that the TCS valve has been removed from the car.
Eckat0100
Jul 5, 2023 09:46 PM
mfgusa
May 20, 2017 06:16 AM
joepenoso
May 28, 2014 11:09 AM
Mr Nick
Nov 24, 2013 06:04 AM
dephconn24
May 8, 2012 11:05 AM
