Need help with horn wire
Old Jun 11, 2023 | 07:29 AM
SRV8's Avatar
Hi I need again help.
My horn on my 1972 Cutlass Supreme is not working.
Where is the cable for the horn at the steering column mounted and if possible does someone know which colors it has.
If someone knows, please give me advice where to find
And which colour has the cable in the engine bay to the horn.
Many thanks Jörg from Germany
Old Jun 11, 2023 | 07:49 AM
The wire that runs from the horn button in the column to the horn relay is black. This wire is the ground side of the relay circuit. Once grounded through the steering wheel horn switch the horn relay energizes and supplies 12v to the horns.
Old Jun 11, 2023 | 07:51 AM
SRV8's Avatar
Hi Eric, where is this black wire located at the steering column (middle left right) , or better is there a connector or something like this
Old Jun 11, 2023 | 07:59 AM
There is a connector at the base of the column that it runs through.
Old Jun 11, 2023 | 08:49 AM
SRV8's Avatar
Hi Eric I found something this should be the right terminal ?
There was a black wire on it
Old Jun 11, 2023 | 10:05 AM
No, that is the neutral safety switch, the connector you are looking for has up to 12 wires in it.
Old Jun 11, 2023 | 08:47 PM
Look higher on the volumn. The switch looks like this:
a
Old Jun 12, 2023 | 05:11 AM
SRV8's Avatar
Hi Matt found it, I found out, that the steering column itself is not groundet (so relais can not work) where is the normal ground of the outer steering wheel in the car under dashboard
Old Jun 12, 2023 | 06:38 AM
SRV8's Avatar
Hi I found the problem,
the outer housing of the collumn is grounded the inner driveshaft where the horn switch goes to is not grounded I need solution and
please hlp ;-)
Old Jun 12, 2023 | 06:59 AM
See if there is a ground strap at the rag joint coupling between the column shaft and steering box.
Old Jun 12, 2023 | 07:02 AM
sysmg's Avatar
On steering rag joint in the engine bay.
Aug 2, 2018 05:04 AM
sealw98
Jun 16, 2016 06:32 PM
tschie
Tech Editor's Desk
Nov 11, 2015 04:35 AM
neatolds
Oct 16, 2015 08:27 PM
Promethean
Oct 19, 2012 03:45 PM
