Mystery Connector?
Old Sep 29, 2025 | 06:23 PM
Charlie D's Avatar
Mystery Connector?
There is a connector under the dash that may tie several of the wires to the instrument panel? At least a few of the wires come from the directional signal connector on the steering column. Evidently its mated connector has been culled from the wiring y the previous owner.If you can help me out I'd appreciate it.What is the mating connector I am evidently missing.
Thank you, Charlie D.
Old Sep 29, 2025 | 07:10 PM
tru-blue 442's Avatar
Old School Olds
Looks to be the connection for the ignition switch on top of the steering column.
Old Sep 29, 2025 | 07:18 PM
What year and model vehicle is this on?
Old Sep 29, 2025 | 08:42 PM
Charlie D's Avatar
1984 Olds 98
Old Sep 30, 2025 | 05:09 AM
This is the 1984 harness that's in your truck? If that's an 11-cavity connector it is C209 body connector that plugs into the RH side of the fuse box.
Old Sep 30, 2025 | 11:23 AM
Charlie D's Avatar
Joe,
It is indeed the C-209 connector. I do not have its mating connector. There are a few things I do not need such as the seat belt warning, low fuel, and left door ajar. I will need the lights circuit. I do need the other half of C-209. The C-209 body connector diagram which the manual says is on page 369. I do not have that page. If someone could scan or take a picture of that page and post it I would be very grateful. My backup plan is to purchase a new 8-wire connector and run the needed wires through it.
Thank you again, Charlie D.
BSiegPaint
Nov 13, 2023 03:43 AM
tkcutlass
Jun 8, 2023 01:10 PM
Dave07
Nov 8, 2022 08:39 AM
rhett838
Feb 21, 2018 07:02 PM
Sampson
Feb 19, 2014 03:12 PM
