my car just clicks
Old Jun 16, 2009 | 12:28 PM
bamaboy_mark's Avatar
Unhappy my car just clicks
I recently finished a rebuild on my 75 olds 455. Everytimg I started to crank it i had to jump it off. I replaced the starter and alternator and still the same problem. My battery still reads its good. I was driving from the muffler shop yesterday and she cut off in traffic. I tried to start I only got the click. I tried to jump it off but no joy. I replaced it with a new battery and still got nothing but the click. I tapped the starter and all. My lights go dim when i try to turn it over. I'm going to test the starter today. I think my alternator might need to have more amps because its only 60 amps. Any other suggestion?
Old Jun 16, 2009 | 01:59 PM
You alternator doesn't make a difference for starting. At least if you haven't started the car before. Make sure your batter has a good charge and make sure your starter is in good shape. You can have them tested for free at your local auto parts store.
Old Jun 16, 2009 | 03:26 PM
My442's Avatar
Troubleshooting is now in order.
Do you know how to do a voltage drop test?
That will allow you to tect the battery cables.
Are your ground straps clean and tight?
If the battery is new, it can only be: cables, solenoid, or starter.
Old Jun 17, 2009 | 04:15 AM
ok I got the starter tested and it was good. I replaced the positive terminal wire and gave the battery a jump and she started. Thanks for the help.
Old Jun 17, 2009 | 04:39 AM
Oldsguy's Avatar
Past Administrator
I figured it would be a battery cable, as My442 said the voltage drop would verify that. The condition you described is either a dead battery or bad cables/connectors. Clicking is a classic indicator of that.
Old Jun 17, 2009 | 08:07 AM
I got to check all my ground cables cause I'm still pulling juice from somewhere.
Old Jun 17, 2009 | 08:16 AM
Oldsguy's Avatar
Past Administrator
That is a very good idea. Let us know what you come up with.
Old Jun 17, 2009 | 09:54 AM
olds68's Avatar
And don't over look the obvious stuff. Re-check your cable connections at both the battery and starter. I had a very similar issue a while back and found the cable connection at the starter was loose. Easy fix and easy to overlook
Old Jun 17, 2009 | 10:26 AM
Ok I'm going to retrace from the battery back.
cwracer
Sep 10, 2013 10:15 AM
jjokrm
Apr 13, 2013 08:26 AM
Freddy B
Sep 17, 2011 07:14 AM
