Looking for Alternator Upgrade Recommendations
The 43 Amp 10si in my '75 98 is on it's way out and I'm looking for a high-output (at least 100 Amp) replacement that will bolt directly into the factory brackets and use the factory harness.
I know there are plenty of high-output 10si units out there, but from what I've read they are known to burn themselves up due to inadequate cooling for anything over 80 Amps.
Anyone have any recommendations? Are there any CS style alternators out there with the rear bolt hole in the correct location for the older brackets?
Does the car have extra non-factory electrical loads? 43 amps is kind of light but 100 amps isn't needed unless there are additional non-factory loads. Point is if 100 amps aren't needed a 10si with much higher output than 43 will get the job done well.
'75 98...what a nice cruiser. Parents had a triple silver Regency sedan.
The alternator will put out the amount of current that is needed by the electrical system. Since you currently have a 43 Amp alternator, I am guessing that is all your system needs. So if you have a 100 Amp alternator and your system is needing only 40 Amps, then the alternator won't burn up due to insufficient cooling.
cfair
September 15th, 2023 07:35 PM
