LED Dash replacement bulbs
Has anyone changed the dash lights with LED bulbs in a 80's Cutlass. The factory gauge lights are dim at night. Looking to change mine so I can see the gauges easily at night. I want to keep the original gauges but just make the lighting brighter. Thanks
Yep, Sylvania 194's also in my '76 Cutlass. Highly recommended, makes a big difference (much easier to see and nice white(slightly blue-ish color, or you can do other colors if you like)
Just keep in mind you can't use the dash dimmer function with LED's. There's a way to get that to work, but I forgot offhand what it was (I just don't touch the dimmer). Hopefully someone else remembers?
james
james
If you don't decide to use LED's, I replaced mine with these. They are traditional bulbs but brighter
https://www.jacksonelectricsupply.co...AaAr85EALw_wcB
