Install dating service parts. Helpful, but a little shade tree looking
As I age I'm depending more & more on labels. I've got a 2 old cars. I sometimes get confused on what I changed when. Over past 10 years or so, when I install a service part, I've started putting an install on the part so I can gauge at a glance how old stuff is and not depend on my memory. It looks a little ugly and not factory, but I like the convenience and confidence of knowing how old stuff is.
Just a sharpie does the trick on lots of parts -- fuel pumps, silver for rubber hoses, etc. Here's my alternator:
Install date marked; Field and Sensor wires labeled to avoid reversing.
Maybe lots of you already do this. I just wish I'd learned to do this in my 20's, not my 40's.
Cheers
cf
Cheers
cf
Yes. Definitely. No doubt about it.
Marking install dates is really for driver cars, not show cars. I don't really show mine.
On the plus side, if I ever decide to switch to a log, I can just use a little lacquer thinner and return the parts to as-delivered.
Great suggestion
Chris
Great suggestion
Chris
As usual, I’m somewhere in the middle. I switch my thermostats spring/fall & write the temp on the stat housing, same w/ fuel filters, sometimes oil filters. On daily drivers I frequently use the bright green 3m masking tape & record basic service info so it is very quick to access as I usually stick it on air cleaner housing. Over time I have mostly kept a log written on the dealer delivery envelope which works well too. That is my bible for 93 F350 (49k Miles) & Mom’s 90 Camry (88k Miles). I also frequently write the oil drain plug wrench size & oil refill volume consistent with the varying service log style.
Oh, this is a different type of "dating service".
I have a log book I maintain for every vehicle & piece of equipment I own w/ complete service history. I do believe your method is a good method none-the-less - I like it.
