Ignition switch won't return to Lock 1970 Cutlass
Old Dec 2, 2018 | 06:06 PM
OLDSter Ralph's Avatar
I bought a 1970 Cutlass 455 auto with power steering. It has an aftermarket floor shifter The ignition won't return to LOCK position and key can't be removed.
What do I need to do to get it working ?
Old Dec 2, 2018 | 07:05 PM
72455's Avatar
1972 U code Supreme
If I had to guess, I would say the neutral safety switch.
Old Dec 2, 2018 | 07:41 PM
classicmuscle442's Avatar
May still have the original rod in column that is stopping key from moving to off position.
Old Dec 2, 2018 | 07:46 PM
Sugar Bear's Avatar
Watch the collar on the steering column where the column meets the dash, it should rotate as the shifter is moved into gear. Try to put it into park and then rotate the collar by hand a little farther in the direction it went going into park. Hold the collar in that position and see if you can turn the lock enough to remove the key. If it works it is probably a linkage adjustment.
If that doesn't work, loosen the ignition switch on top of the steering column and try the lock,
If loosening the ignition switch doesn't work it is probably the ignition lock cylinder or less likely and internal problem in the collar.
Good luck!!!
Old Dec 3, 2018 | 10:14 AM
I've got $10 that says whoever installed the aftermarket shifter did not reinstall the backdrive linkage. Grab the collar on the steering column where the shift lever would have been and twist it as far counterclockwise as it will go. Your key will likely work now. Unless the shifter has a self-contained backup light switch, I'll assume your backup lights don't work either.
Old Dec 3, 2018 | 10:37 AM
Sugar Bear's Avatar
I'm not taking that bet... don't like losing
67Rocket
Oct 18, 2019 03:21 PM
deaddds
Hurst/Olds
Apr 15, 2018 03:59 PM
pcard
May 5, 2017 04:45 PM
Dmaxheimer@bellsouth.net
Sep 26, 2015 12:49 PM
HLS
Feb 8, 2015 05:42 PM
