ignition switch terminology
And to expand on Eric's response, the Key - terminal is connected to a white wire that is grounded when the driver's door switch is closed (door open closes the switch). The Key + terminal is connected to the pink/black wire that goes to the buzzer terminal on the horn relay. When the key is in the lock cylinder in the OFF position, the Key + and Key - terminals are connected internally in the switch, which grounds the buzzer terminal on the horn relay and produces that annoying sound.
Note that this is unique to the 1968 cars. With the locking steering column in 1969, this key buzzer switch function moved to a separate set of contacts in a housing next to the lock cylinder that close when the key is in the LOCK position.
mm89olds
April 6th, 2006 11:03 AM
