HVAC Fan issue 69 442
Most likely cause is a stuck high speed blower relay if the car has A/C. Sugar Bear is asking the correct question.
While I think the relay is the most likely cause, unless you have money to throw away, you might want to try some no-cost troubleshooting BEFORE throwing parts at the car. First thing to do is to disconnect the high speed fuse on the driver side inner fender. The fan should stop. Now try the lower speeds. If none of them work that increases the likelihood that the problem is the relay. As a final check, disconnect the wires from the relay and jumper the purple wire to the blue one. The fan should work normally on all speeds except HIGH. If this is the case, it's definitely the relay. If not, there is another problem.
