HVAC Fan issue 69 442
Old Jan 30, 2022 | 02:13 PM
Crimson@69442's Avatar
My heater fan stays on with the switch in off position. The switch does switch speeds low thru high. Could the fan switch be bad or some other cause.
Thanks,
Mike
Old Jan 30, 2022 | 02:17 PM
Sugar Bear's Avatar
AC car?
Old Jan 30, 2022 | 02:38 PM
Charlie Jones's Avatar
Phantom Phixer
This was a purposeful feature of the " Astro- Ventilation system ". Developed after the elimination of the vent windows in the front doors.
Perfectly normal operation .
Old Jan 30, 2022 | 02:45 PM
Not on the 69 A-body cars. RPO C57 Forced Air Body Ventilation was a very rare option on the 1969 2drs. I've never seen one myself. The C57 blowers are separate from the HVAC blower motor and have a separate control switch to turn them off and on. This is from the 1969 owner's manual:
Most likely cause is a stuck high speed blower relay if the car has A/C. Sugar Bear is asking the correct question.
Old Jan 31, 2022 | 06:16 PM
Yes, its an A/C car I will try replacing the high speed blower relay.
Old Jan 31, 2022 | 06:26 PM
While I think the relay is the most likely cause, unless you have money to throw away, you might want to try some no-cost troubleshooting BEFORE throwing parts at the car. First thing to do is to disconnect the high speed fuse on the driver side inner fender. The fan should stop. Now try the lower speeds. If none of them work that increases the likelihood that the problem is the relay. As a final check, disconnect the wires from the relay and jumper the purple wire to the blue one. The fan should work normally on all speeds except HIGH. If this is the case, it's definitely the relay. If not, there is another problem.
Old Jan 31, 2022 | 06:42 PM
Thanks for the info, I will try these tests!
wherlehy
Nov 27, 2021 12:41 PM
bobfo1
Jul 23, 2020 10:32 AM
2mule
Jun 26, 2017 06:20 PM
Arthur T. Berry
May 2, 2014 02:04 PM
HammerVette
Mar 26, 2014 07:34 PM
