how to remove dash to replace radio in cutlass
I am replacing the radio in my 70 cutlass supreme with a new retrosound model. I have done some searching on the site and couldn't find what I was looking for as what all I need to remove to get at the radio. Could you guys help me out with what I need to remove and how? Thanks
Been awhile, but, I beleieve you pull the ***** off, loosen and remove the nuts that were behind the *****, lay on your back with a flash light and look up at the back of the radio for brackets and wiring harnesses to remove from the deck.
Remove the under dash valience (6-8 screws?). Remove the lower air plenum (2 screws), disconnect a few ducts from it & push them up out of the way. The radio will come out fromt he back. Dash itself stays in. Heck I found that even the heater box will come out with the dash IN!
HitTheHole
June 30th, 2014 04:12 PM
nottyleradams
May 29th, 2014 09:05 AM
KRICHEN922
July 1st, 2010 10:17 AM
84oldsDelta88
December 31st, 2009 11:18 AM
