how to remove dash to replace radio in cutlass
Old May 23, 2012 | 11:37 AM
Finn5033's Avatar
I am replacing the radio in my 70 cutlass supreme with a new retrosound model. I have done some searching on the site and couldn't find what I was looking for as what all I need to remove to get at the radio. Could you guys help me out with what I need to remove and how? Thanks
Old May 23, 2012 | 12:08 PM
boese1978's Avatar
Been awhile, but, I beleieve you pull the ***** off, loosen and remove the nuts that were behind the *****, lay on your back with a flash light and look up at the back of the radio for brackets and wiring harnesses to remove from the deck.
Old May 23, 2012 | 12:10 PM
Finn5033's Avatar
so I don't need to remove the dash to do this?
Old May 23, 2012 | 12:41 PM
1970cs's Avatar
Lansing built
x2 on boese response
Old May 23, 2012 | 12:44 PM
There may be some air ducts in the way though.
Old May 23, 2012 | 01:04 PM
Lady72nRob71's Avatar
Remove the under dash valience (6-8 screws?). Remove the lower air plenum (2 screws), disconnect a few ducts from it & push them up out of the way. The radio will come out fromt he back. Dash itself stays in. Heck I found that even the heater box will come out with the dash IN!
Old May 23, 2012 | 01:11 PM
vette442's Avatar
There should be a long, clear plastic strap coming down from the top the dash - this will be attached to the side of the radio housing. Make sure that is disconnected as well.
Terry
Old May 23, 2012 | 04:33 PM
Would it help to see how it goes together? here's a link to the 1970 Cutlass Assembly Manual. The radio is in sec 1-3, pages 130, 131 http://wildaboutcarsonline.com/membe...to_Sec_1-3.pdf
Old May 24, 2012 | 08:50 AM
Finn5033's Avatar
@lady72, you were right on the money had no problems. Thanks
Old May 24, 2012 | 09:36 AM
I'm always happy to share my past repair experiences - glad it helped!
Redog
Jul 18, 2014 09:06 AM
HitTheHole
Jun 30, 2014 03:12 PM
nottyleradams
May 29, 2014 08:05 AM
KRICHEN922
Jul 1, 2010 09:17 AM
84oldsDelta88
Dec 31, 2009 10:18 AM
