Horn ring/turn signal issue.
Old Jun 22, 2021 | 07:13 AM
KCastl03's Avatar
68 442 2 door post Horn ring/turn signal issue.
If I have the new horn ring mounted on the column, the turn signal being in engages the horn. Anyone have any good fixes for this issue? I’m stuck. Thanks!
Old Jun 22, 2021 | 10:35 AM
Year, model, steering wheel, and photos would probably help you get useful answers.
Old Jun 22, 2021 | 11:30 AM
KCastl03's Avatar
Sorry thought I did. 68 442 2 door post coupe.
Old Jun 22, 2021 | 11:32 AM
You did, it was in the title that I breezed right past. Sorry. Now, which steering wheel? The stock three spoke or the woodgrain?
Old Jun 22, 2021 | 12:53 PM
KCastl03's Avatar
Wood grain but it’s the brass ring underneath. I replaced it and bought a new spring and pin for it and when I set it on there and push the horn will work but then it makes a connection with my turn signal arm and when I turn the turn signal on the horn blows.
Old Jun 22, 2021 | 01:07 PM
Then you have a problem with the turn signal switch or how the cancel cam was installed. The cancel cam contacts the brass pin on the turn signal switch. If that cancel spring is out of position, it can touch the brass pin or the slip ring on the underside of the cancel cam, causing the horn to blow. It could also be a short in the horn wire that runs in the turn signal switch harness.
Old Jun 22, 2021 | 01:19 PM
72455's Avatar
1972 U code Supreme
Had a similar problem on my '72 Supreme and after extensive troubleshooting, I figured out that the "insulator" ring was missing from the cancel cam and this caused a dead short to the brass ring in the cam. I would check that.
If you look closely, you can see a portion of the insulator ring I'm talking about.
cfair
Oct 13, 2020 12:30 PM
72455
Aug 2, 2018 05:04 AM
70Post
Jul 23, 2018 08:03 PM
SnakeBit
Mar 9, 2016 08:02 AM
Rios69Cutty
Oct 18, 2012 04:22 PM
