horn pigtail
horn pigtail
i read somewhere i could get the pigtail from dorman that goes under the horn button on a rally wheel on a 1980 calais and i wrote it down and promply lost it. if any one knows i would really appriate it, or one from another cat that would fit. thanks in advance and merry christmas.
I can't answer your question, but I do know that both the Droman and RockAuto sites have listings by year and model, and RockAuto generally has a "Plugs and Wiring" (or something like that) section for each car year and model.
Good luck!
Good luck!
1980 olds cutlass horn wiring
i saw somewhere the dorman part no. for the pigtail wiring in the horn pad .the little wire that goes down inside the little spring. i need that wire or the whole kit with the wire,spring,and little plastic piece any help will be most appriciated.
