horn pigtail
Old Dec 13, 2015 | 07:27 PM
neatolds's Avatar
horn pigtail
i read somewhere i could get the pigtail from dorman that goes under the horn button on a rally wheel on a 1980 calais and i wrote it down and promply lost it. if any one knows i would really appriate it, or one from another cat that would fit. thanks in advance and merry christmas.
Old Dec 14, 2015 | 04:13 AM
I can't answer your question, but I do know that both the Droman and RockAuto sites have listings by year and model, and RockAuto generally has a "Plugs and Wiring" (or something like that) section for each car year and model.
Good luck!
Old Dec 14, 2015 | 07:20 AM
Are you talking about an actual wire pigtail, or the pin and spring used on the four-spoke wheel? If the latter, this is the same on 67-69 Camaros, and EVERY Camaro repro vendor sells them for about $5 a set.
Old Mar 2, 2016 | 06:31 PM
neatolds's Avatar
1980 olds cutlass horn wiring
i saw somewhere the dorman part no. for the pigtail wiring in the horn pad .the little wire that goes down inside the little spring. i need that wire or the whole kit with the wire,spring,and little plastic piece any help will be most appriciated.
Old May 23, 2016 | 08:44 PM
damnolds's Avatar
i found one at napa
pfergy600
Nov 18, 2018 07:29 AM
joepenoso
Jul 12, 2013 11:03 AM
DennisG.
Apr 15, 2012 11:01 AM
oldsmobill66
Jul 25, 2011 12:19 PM
orange442
May 14, 2006 03:03 PM
