Help identify my alternator
Hello,
Please see photos. This is installed on my 65 F85 Cutlass with a 330. Based on the limited amount of research I've done, it looks like a 10DN, can you confirm?
It makes a screeching/grinding noise and needs rebuild or replacement. I'm open to rebuilding myself, if it's a fairly straightforward process. Has anyone here done this? Are rebuild kits available?
I would also consider changing to a 12Si or CS130, not sure yet.
Thanks!
Thanks!
