Headlight problem
Headlight problem
'72 Cutlass
When I put my headlights on at night, (I don't drive much at night) I noticed that they slightly dim and then go back to full brightness about every second or so. It makes no difference if it's high or low beams. I tried replacing the voltage regulator, but no change.
I can hear a click somewhere under the dash as this happens. Any ideas what the problem may be?
Me too. Eric, IMHO, if the circuit braker loses contact the lights generally don't go dim. In most of my old gm cars, the issue the op is describing is a weak alternator or the idle is too low.
