Ground Strap location
I have a ground from the battery to the engine block. I've tried to find the ground strap location for the block to the body in my CSM but could not locate it. I believe it goes from the passenger side cylinder head to the firewall somewhere. Can anyone advise?
Is that ground strap actually on the block or is it on the head? It appears to be on the head. I've got to install the ground strap on my '69 but it's pretty difficult reaching down in there. I've been trying to find a threaded hole in the block but haven't seen it thus yet!
Randy C.
Randy C.
I haven't had any issues as far as I know, not much of a cassett radio to worry about or other electronics, but I will clean it up and put it back on next weekend .
Good thing this thread came up.
Thanks to RROLDSX and Eric!!!
While some cars find good grounds in other ways others don't and the ways they find ground are through shifter linkage, cables, etc. GM as Joe P puts it will try and save money every chance they get, yet that tiny little ground strap was installed. It must have been important.
Normally fairly small, 14/16ga. I have a bad habit of braiding whatever smaller scraps I have on hand to make something decent.
JackJack56Olds
November 27th, 2016 07:00 PM
pfergy600
July 6th, 2014 07:55 PM
