Gauges - questions thoughts ('70 Cutlass)
Old Jun 9, 2026 | 08:54 AM
Willardx1's Avatar
So I am building my '70 Cutlass to be reliable, solid and semi-original. Semi-original means, keeping the bench, keeping the 350 rocket, carb, factory AC, oem look wheels, etc, but upgrades where it makes sense. When I bought the car, I discovered the fuel gauge was shot and the PO or the one before him, put in a aftermarket fuel gauge.
So I will have to replace that. Additionally mine came with the clock (not sure if it is working....probably not). I do not like idiot lights and many times they will go off when it is almost to late. I am thinking should I go with the Rallye Gauge Pack (it is just a general sweep set) or get a OEM replacements for the gauges that are not working (Fuel) and go with an under the dash (or maybe something unique where the ashtray is) mount and put in a trio set with mechanical oil and water, with the third being volt and maybe a vacuum gauge for fun.
What are your thoughts on the rallye gauge pack and is it worth it at $500 about for the set + wiring that is a chunk of change I can use elsewhere. I am not sure if it is outside of the tach, even then I am not racing this just driving it so is a tach even needed? I have one in my '74 Nova, but that is 100% setup for drag racing and the tach is used (well, really everything is on the control boxes).
Or stick with a clock (ideally working).
Old Jun 9, 2026 | 12:52 PM
I installed a tach and gauges back in 1981 and have become so accustomed to having them that I don't think I could drive without them.
Old Jun 9, 2026 | 01:13 PM
HydraMatic's Avatar
I installed a tach and gauges back in 1981 and have become so accustomed to having them that I don't think I cold drive without them.
That's a great photo.
Old Jun 9, 2026 | 01:39 PM
fleming442's Avatar
M&H probably has a plug and play harness to do the swap all factory like.
I fixed a 62 clock, once. It was fun, but I had a spare for parts and reference. It had a little solenoid that would kick the winding mechanism when the contacts closed. If you don't drive the car much, it WILL drain the battery. Use a good trickle charger.
Mossy
Mar 20, 2020 02:25 AM
cfair
Aug 27, 2019 04:17 AM
sjay1989
Mar 20, 2019 08:23 PM
thunder66
Jun 28, 2012 10:18 AM
Olds luvr
Nov 28, 2009 08:10 PM
