Gas Gauge Problem
Old Dec 8, 2010 | 07:28 PM
sincitycutlass's Avatar
Angry Gas Gauge Problem
Hi everyone,
Having an issue my gas gauge in my 72 Cutlass is not working! So i dropped the tank cleaned it out put in a new sending unit and also connected the ground and its still not working. Im not sure what the deal is any information i would greatly appreciate. I heard i might have a wire in the trunk not connected but im not sure. Thank you all and HAPPY HOLIDAYS
Old Dec 9, 2010 | 05:22 AM
Lady72nRob71's Avatar
Do you have an ohmmeter available? What is the measurment from the sending unit wire to ground?
Have you had the gauge itself out yet? When you say not working, what does it do? Does it point to the 3 o clock position?
Old Dec 9, 2010 | 04:02 PM
its pointing past full like around 3 oclock let me take a pic give me a lil bit
Old Dec 9, 2010 | 04:10 PM
Rickman48's Avatar
Had the same situation on a 'vette I worked on - find the ground wire, and clean or replace it!
Old Dec 9, 2010 | 05:49 PM
hamm36's Avatar
https://classicoldsmobile.com/forums...fuel-guge.html
I had the same problem a couple years ago, here is the way to check your gauge and the way I fix my issue.
Old Feb 3, 2011 | 05:27 PM
ok i found out i needed to connect the postive brown wire to the top of the sending unit i purchased the wire connected it and now when the gauge is empty it says its 1/2 and now half a tank is on the F (full)... a mechanic friend of mine connected grounded the postive brown wire he said it should of read empty so he thinks the something wrong with the gauge itself.
JPMDaddy
Jan 31, 2020 04:01 AM
BStone
Aug 2, 2012 07:56 AM
IZAOLDS
Apr 10, 2011 05:04 AM
trez
Mar 23, 2011 12:20 PM
Pete77
Jul 9, 2006 03:11 PM
