fuse box
Old Jul 30, 2009 | 09:50 AM
AZ442's Avatar
fuse box
Electrical Advice on a 1970 442
My fuse box is dead on the hot at all times side. How many wires and what colors feed this box and are they coming from the horn relay?
If I remove the 2 screws from the fuse box on the inside how does this come apart? Don't want to damage it.
Thanks.
Old Jul 31, 2009 | 07:47 PM
gearhead1218's Avatar
See my thread on "Fuseable link replacement".
The link feeds the majority of the power to the fuse box.
Old Aug 1, 2009 | 02:51 AM
Yellowstatue's Avatar
Thumbs up Hot
There is one red wire coming off the fusible link (at the horn relay) to the fuse panel...
Old Aug 18, 2009 | 06:54 AM
AZ442's Avatar
I still don't have a service manual or any $. But do have an electrical cluster. I found the 10G red wire cut back 6" from the horn relay I can read contanuity from the wire to the fuse box but when I apply power to it the starter turns over. Everything has been routed around the fusebox. Breaks light are pluged into the side of a fuse on the ACC side of the box.
I know get a service manual.
Get this one. When I start the car the floor lights come on while the key is in the start position only.
Original auto car now 4 speed.
Old Aug 18, 2009 | 07:53 AM
Lady72nRob71's Avatar
Try this one... It is for a 72 but could help you some... The 70 442 will have some differences int he engine harness...
https://classicoldsmobile.com/forums/...html#post65982
Hope this helps...
Oldscutty72
Dec 28, 2015 01:56 PM
65 starfire
Jan 13, 2009 05:13 PM
silverriff
Jul 6, 2008 04:18 PM
nickpit21
Mar 8, 2008 11:49 AM
denis
Jan 17, 2007 10:14 AM
