is this a condenser?
Old Aug 3, 2009 | 09:46 AM
jaunty75's Avatar
This is attached to the coil. One suggestion was that it's just a noise supressor for the radio, but I'm not sure. It looks like a condenser, but it's not hooked up. Where does that lead that's just dangling there attach?
Does a '67 Delta 88, 425 2-bbl use a condenser? I cannot find a mention of it in the service manual. But Autozone, for example, sells a condenser for this car. I presume they wouldn't sell it if it wasn't a needed part.
This one looks like it's kind of shot, anyway, and a new one is only about $6.00, so I can certainly put another one in.
What are the consequences if this is a condenser and it's not hooked up? The engine starts and runs fine.
Thanks!
Old Aug 3, 2009 | 09:49 AM
If you don't run a condensor you will eat points faster.
Old Aug 3, 2009 | 09:50 AM
jaunty75's Avatar
Thanks. I kind of figured it wasn't good. Where does that lead wire attach?
Old Aug 3, 2009 | 09:51 AM
To the points side of your coil.
Old Aug 3, 2009 | 09:55 AM
jaunty75's Avatar
Thanks. I apologize for the dumb questions, but is that the positive or negative side of the coil? One wire attaching to the coil comes from the distributor. Is that where the condenser attaches?
Old Aug 3, 2009 | 09:59 AM
Yes.
No such thing as a dumb question. I said "points side" because I also forgot if it is the + or - side.
Old Aug 3, 2009 | 10:03 AM
jaunty75's Avatar
Thanks!
Like I said, one wire going to the coil comes from the distributor. The other comes from the wiring harness. I'm guessing that the one from the distributor is the one I want.
Old Aug 3, 2009 | 10:06 AM
Yes.
Old Aug 3, 2009 | 10:29 AM
Lady72nRob71's Avatar
A condenser is just another term for capacitor. The important one is across the points, usually under the disty cap. This one must stay. It looks like yours may have been externally mounted...
You may also have a condenser on the horn relay coil circuit and the voltage regulator to eliminate radio noise.
Old Aug 3, 2009 | 10:45 AM
jaunty75's Avatar
Thanks. I do see something that looks like this attached to the voltage regulator.
Old Aug 3, 2009 | 11:03 AM
88 coupe's Avatar
Junior Member
Originally Posted by jaunty75
........ One suggestion was that it's just a noise supressor for the radio ........
Exactly what it is. The values are different than the ones used (under the cap, attached to the points) in ignition systems.
Norm
Old Aug 3, 2009 | 11:15 AM
jaunty75's Avatar
Norm
So what you are saying is that I do NOT need to buy a new one of these and attach it where this one was? The condenser I'm thinking about is under the distributor cap, and it's probably been working fine because, as I say, the car starts and runs fine?
Old Aug 3, 2009 | 11:44 AM
88 coupe's Avatar
Junior Member
Only if you have an RFI problem.
Norm
Old Aug 3, 2009 | 11:50 AM
56chevy's Avatar
The only reason to replace this condenser is for a radio noice problem or if you are trying to get things back to original. Hope this helps!
Old Aug 3, 2009 | 01:18 PM
jaunty75's Avatar
Actually, the radio doesn't work and is out of the car while I figure out what I'm going to do about it, so I've never had a chance to see if there is ignition noise. (I've had the car only since the end of June.)
Old Aug 19, 2009 | 03:13 AM
oldstrio's Avatar
THAT ONE DOESENT HAVE ANY THING TO DO WITH YOUR POINTS IT'S FOR NOISE SUPPRESION ONLY (RADIO)
Old Aug 19, 2009 | 06:38 PM
jaunty75's Avatar
Thanks.
ashtons 56
Ninety-Eight
Jul 27, 2009 09:31 AM
Nailhead 88
Jun 22, 2009 01:59 PM
ashtons 56
Jun 3, 2009 01:41 PM
68Tom
Apr 16, 2009 07:28 AM
Tangovino
Nov 18, 2008 04:09 PM
