fuel gauge not working 1970 olds 442
Old May 11, 2015 | 08:42 AM
Dbechtel71's Avatar
hello again, so I put a new gas tank and fuel sending unit in and just put five gallons of gas in. the gauge does not come off empty. I cleaned the ground and still wont work any thoughts?
Old May 11, 2015 | 12:32 PM
Remove the tan wire from the sender and see if it goes past full with the key on. If it does then your circuit is working right but your grounded somewhere at the tank or sender.
Old May 11, 2015 | 02:59 PM
Dbechtel71's Avatar
so yes it does go all the way past full. what do you mean by grounded? do I have a bad ground?
Old May 11, 2015 | 03:39 PM
If you ground that same wire with the key on it will do exactly what your gauge is doing when it's connected to the sender. Whats happening is the circuit is finding a ground and not reading through the sender. All your wiring from the tan wire back to the gauge is fine, so your problem is either the sender or the sender wiring.
Old May 11, 2015 | 04:15 PM
Dbechtel71's Avatar
ughh!! its a brand new sender.
Darin Matera
Nov 12, 2014 07:04 PM
Markwz11
Apr 4, 2014 02:29 PM
nelsontj
Aug 3, 2013 05:00 PM
Nails
Sep 7, 2011 03:30 PM
Kidcutty
Feb 10, 2011 09:05 AM
