front turn signal connector
Old Jul 14, 2014 | 08:42 AM
Macadoo's Avatar
Anyone know how to remove this connection? Power to the signal was intermittent, now it's nonexistent. At first I could jiggle the wires where they entered the housing and it would work.
Thanks...
[IMG][/IMG]
Old Jul 14, 2014 | 10:13 AM
Thanks...
You can't, at least not without destroying the housing. That is not a "connector" and is not intended to be separable. Follow those wires the other way and you'll find the real connector.
Old Jul 14, 2014 | 12:44 PM
Macadoo's Avatar
Okie dokie, thanks Joe. Looks like i have some rewiring to do.
Old Jul 14, 2014 | 12:55 PM
Or, get another parking light housing (repros are available), unplug this one, plug in the new one.
Old Jul 14, 2014 | 01:07 PM
RandyS's Avatar
It may just be that the socket has some corrosion in it and the little springs behind the contacts aren't allowing them to make good constant contact with the bulb base. Remove the bulb and spray some silicone inside the socket and see if you can loosen up the springs by pushing down on the tips and releasing them a few times. I have had to do that with just about every socket on my 66 .........
Old Jul 14, 2014 | 02:08 PM
Macadoo's Avatar
No need.....yet
That was the first thing I tried. It actually turned out to be the connection behind the battery. It was corroded as all get out. Remembered a trick from When I was a [faux] science teacher. I soaked the connections in vinegar and salt and then rinsed and dried. Cleaned them right up. Yay, left turn signal!
Old Jul 14, 2014 | 04:38 PM
RandyS's Avatar
If they could all be that easy.........
Old Jul 14, 2014 | 06:49 PM
Macadoo's Avatar
Amen to that.
Old Jul 14, 2014 | 09:32 PM
Don't forget to put some dialetric grease into the socket. It will help prevent future corrosion.
Old Jul 15, 2014 | 04:56 PM
Macadoo's Avatar
Yup, did that. But thanks for the reminder.
costpenn
Jun 24, 2015 10:38 PM
Mr Nick
May 27, 2015 11:06 AM
1966Oldsmobile
Jan 18, 2013 01:19 AM
slowolds
Jun 28, 2009 06:55 AM
cbogartjr
Aug 3, 2008 06:18 AM
