Fiamm air horn plus regular horn
Old Jul 11, 2013 | 07:59 PM
joepenoso's Avatar
Question Fiamm air horn plus regular horn
I have a Fiamm air horn in my 71 442. I would like to also add the 2 original type electric horns that each have a single spade connection.
There is a square shaped relay numbered 87 and 87a North-South (Top- bottom) of the relay. Top 87goes to the Fiamm compressor. Bottom ( South) is hooked to the green wire running into the wiring harness.
West--East ( Left- right) of the relay is numbered 86 and 85 respectively.86 (West-Left) goes to a common ground.
85 (Right-East) is hooked up to a double green wire that goes into the harness.
Question.......................................... ...how do I make the other 2 electric stock type horns work with this setup in the most expedient way?
Thanks in Advance
joepenoso
Old Jul 11, 2013 | 08:12 PM
Ummmm... Hook them up to the same terminal as the Fiamm horns.
Old Jul 12, 2013 | 05:10 AM
joepenoso's Avatar
Fiam air horn is a single air horn with relay #87 single wire. Should I add two wires to this each going to a separate horns?
joepenoso
Old Jul 12, 2013 | 05:53 AM
These relays generally have 1/4" spade lug connectors.
You can get spade lug adapters from places like Radio Shack that turn one lug into two, so you can plug in two wires.
There are also some relays with two #87 terminals.
Old Jul 12, 2013 | 06:57 AM
joepenoso's Avatar
Thumbs up
joepenoso
Old Jul 12, 2013 | 10:31 AM
joepenoso's Avatar
Talking
F.Y.I.
Worked like a charm
I was afraid of a melt down ...................everything OK
joepenoso
Old Jul 12, 2013 | 11:03 AM
You're welcome.
Finn5033
May 29, 2012 05:20 PM
FSTGeek
Jan 26, 2011 07:14 PM
stonedglass
Nov 24, 2010 09:48 AM
my69olz
May 11, 2009 12:29 PM
easytobedead
Aug 27, 2008 10:25 AM
